1. FrancW
  4. Friday, 11 June 2021
How to change the size and styling of H1 into H2 size and styling, using Noami without losing the H1 tag?
tia
hi Ciaran,
i've changed the 2000 to 800 and for both sites it did the trick, so i'm fine.
i've added
h1 {
font-size: 2.2em;
font-weight: 300;
to the custom css wich did the trick, but to get the page header before after added?
Presuming I understand you correctly and you wish to add the bottom border effect, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
h1 {
overflow: hidden;
h1::after, h1::before {
position: absolute;
display: block;
content: '';
height: 3px;
bottom: 0;
margin-top: 5px;
h1::before {
left: 0;
width: 60px;
background-color: rgba(100,100,100,0.1);
background-color: var(--primary);
h1::after {
left: 63px;
width: 2000px;
it works nearly perfectly. I've changed the h1 after width to 800px as the 2000px was to width and caused a horizontal slider. 800px is perfect for the articles.
Franc
Hi Franc
Would you have a URL to an example of the horizontal slide issue?
the site is kokkieblanda.nl or asiancook.eu but with 800px it works on the site and on the responsive version
Have you since been able to resolve the horizontal scroll as we are currently unable to replicate this issue?
