1. arranmanagement
  3. Sunday, 28 October 2012
Hello Ciarán,
On the Executive template, how do I change the main menu from all upper case to upper and lower case? I've searched the source code with Firebug, but I do not see how to set that in the CCS/template files.
Not sure if this matters, but I've changed the main menu to a module positions.
As always, cheers!
-MT
Hi MT
Try adding the following CSS to the Custom CSS field within your templates parameters..
[code type=css]#hornav ul a, #hornav .separator {text-transform: none;}[/code]
This worked! Thanks so much!
