1. Digijoom
  4. Friday, 16 March 2018
I'm using the template Artisan for a website. It is used for several locations in one website. For each location I made a copy of the Artisan template.
Now I'm having about 10 templates (copies) in one site.
I have changed something in the index.php file from copy 1. But I recognized that there is still one index.php. So my customization is shown in every copy template.
How can I made a another change in the index.php of each copy ?
Thanks for your answer. I have made duplicates of the actual template files and changed some settings (logo etc) in each copy. Then I uses the copies for several menu's.
In the meantime I have found a solution myself. I have made a new module like you wrote in a tutorial in youre site. And I can use the new module per template if I want.
So this is how I did the job.
Thanks anyway for your quick response.
Best regards
Kees
I am not sure if I understand you correctly. Have you made duplicate templates styles or duplicates of the actual template files? To better understand your issue may I suggest sending temporary administration access to your Joomla installation to [email protected]. For our reference please paste a link to this post in your email.
