1. jermainenw
  3. Saturday, 04 May 2013
Hi guys, I'm using your j51_catalyst template for my website and really love it.
However, I am having a small issue with the colour of the module boxes and contact form and can't see how to change it.
To give you an example of what I mean, here are the links to the pages in question:
http://footprintmusicproductions.com/services/gift-vouchers
and
http://footprintmusicproductions.com/contact-us
For the second link, please click on the drop-down box. You will see that the options there are very feint. On the 'gift vouchers' page, the details in the white box are almost unreadable.
I have tried going into the template manger to change font colour, but ideally I think I need to change the actual colour of the white area and I can't seem to do this in the template manager.
Please note that the extensions used on these page are different and appear to use the colours that are set in the template.
I hope someone can help me on this.
Thank you,
Jermaine.
Thank you Ciaran, much appreciated!
Hi Jermaine
Try adding the following to Custom CSS field of your templates parameters...
[code type=css].dm_props {color: #000000;}[/code]
Where #000000 is your new text colour.
Perfect!
Just one last thing, if you go to this page: http://footprintmusicproductions.com/component/osmembership/?view=plan&;id=1&Itemid=134
you will notice that there is a box on the right of the page with text in it that is also unreadable. (It is part of the membership pro extension I have installed). Is it possible to make the background for this box transparent, or make the text black?
Thank you again.
Jermaine.
Hi Jermaine
Try adding the following to the Custom CSS field of your templates parameters..
[code type=css]div#foxcontainer_c109 .chzn-container .chzn-results li {
color:#000000;
}[/code]
Where #000000 is the new colour to the dropdown items of your contact extension.
Thanks for that, it worked perfectly.
I regards to the contact page, you will see that the writing in the drop-down box is almost unreadable. But I'm reluctant to change the colour of the font as I feel it will change it on all the pages.
Any Ideas?
Thanks,
Jermaine
Hi Jermaine
For http://footprintmusicproductions.com/services/gift-vouchers I presume you are referring to the white subscriptions box, try adding the following to the Custom CSS field of your templates parameters...
[code type=css].dm_row {background: none;}[/code]
This will remove the white background image on the modules.
Could you detail for us what changes you would like made to the contacts page?
