I recently had requested some coding for the Everly template where you helped me add red underlining on some modules.
You also gave me css coding to set the default position of the header.
My client has requested to change to a wide template with a full width slideshow along with 100% wide module positions.
You can see what I have so far at the link http://tempdomain51.site .
I have attached a graphic illustration for the homepage below of what they sent me originally before they wanted me to change to a full width design.
I am now attempting to change to the Ensley template but when you scroll down the header goes completely black and the logo shrinks.
They would like the default position be a semi-transparent header as was in the Everly template and without the logo shrinking and not go black.
I don't know if that is possible or not.
The other request was to have pipe symbols as dividers between the menu items.
The last thing would be how to eliminate the blue vertical bars on the left of the Module headings.
I had everything working well with the Everly template but I am hopeful I can change over to the Ensley template.
Again, I really appreciate your coding talents with all of your templates!
James
