1. Reusfotografie
  3. Thursday, 02 January 2014
Hai Clarian,
Is it possible to change the background colour grey in totally white in the Clarity template where the logo and the slideshow are defined?
Presuming I understand you correctly to change the background of the slideshow area of your template to white try adding the following to the Custom CSS field of your templates parameters...
#container_slideshow {
background: #FFFFFF;
The background to the logo image uses an image (http://demo.joomla51.com/0095/templates/j51_clarity/images/bg_bar.png) which you will need to edit directly within your templates core files. You will find it located at ../templates/j51_clarity/images/bg_bar.png from the root of your Joomla installation.
That was exactly what I mend. I can change it now. Thank you for your answer and best wishes for 2014!
