1. Internetional
  3. Sunday, 15 November 2015
I would like to know if the following changes to the Hornav Menu (Main Menu) are possible and if yes how? Or is it better to use a different menu?
[ul]
[li]Changing the textcolor of the links on dropdown lists[/li]
[li]Making titels in menu not klickable, just the links on dropdown lists are klickable[/li]
[/ul]
http://joomla.noobinator.de/index.php
Thanks and regards,
Ing
1. To amend sub menu item link color try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
#subMenusContainer a {
color: #FFFFFF;
2. To remove try also adding the following to your Custom CSS field...
#hornav > ul > li.parent > a {
cursor: auto !important;
Hello Ciarán,
thanks again for your great support :)
color: #FFFFFF;
[/code]
Works perfect.
Does prevent the mouse cursor to change to hand symbol on mousover the menu titels with drop down list but the titels are still klickable.
Thanks and regards,
Marek
I have solved this issue for my needs.
I have selected as "Menu Item Type" -> "Menu Heading"
Now a klick on the titel links to the start page. Thats ok for me.
I didn't try it, but I guess once hast to choose this menu item type after choosing "List All Categories" or what ever is the intended menu item type.
Thanks and regards,
Marek
Hi Marek
Thank you for sharing your solution!
Kind regards
