1. MySigma
  4. Thursday, 25 June 2020
is it possible to change the width of the multi column dropdown menus?
Thanks and Regards,
Manfred
Hi Manfred
At present this is only possible with the inclusion of some CSS. Would you have a URL to an example of your menu and the width you wish to use?
Can I send you an email or PM? I don't want to make this temporary homepage available to the public.
Manfred
Hi Manfred
Sure. Details can be sent to info@joomla51.com. For our reference please paste a link to this post in your email.
(edit to taste)
.hornav .item-131 ul ul {
width: 200px;
Hi!
Thank you! This CSS just working for the EN menu, so I would have to change it also for the DE menu?! Is the menu-id the item-xxx.
Manfred
Yes exactly. Simply repeat and replace the ID with that of the parent menu item. ID's can be found in the right column in your menu manager,
