1. Welker
  3. Wednesday, 24 January 2024
Hi there,
in Germany Strato is ending PHP 8.0 and 8.1 is the new.
The Problem: Templates like J51Riley and other are not working correctly wit this version.
There are a lot of errors seen un the page like picture ...
WHAT TO DO???
These are not errors, but warnings. They will disappear if you set PHP variable "display-errors" to false.
Anyway, Ciaran should take care of those.
... some more infos: Thats the problem with Joomla 4.x. Pages with Joomla 3.x are working fine under 8.1 but 3.x isnt supported at all
Hi Dautrich, thanks for your help! It just works and i have never thougt Joomla will give error messages in the frontend...
Assuming you are running Joomla 4, updating your template to the latest download should resolve this issue for you.
