1. MaZe01
  3. Sunday, 29 December 2013
on my website is a hornav menu, which continues on many pages in the sidecol-a in Oxygen-Temlate.
Now i would like to change the font weight and color of the heading in the sidemenues? When i try it, the headings as well as the listed items are bold.
Link to Homepage: Homepage
Also check the Screenshot
Thanks for your help!
Presuming I understand you correctly you wish to edit the parent items separate to the sub child items?
First you would style all the items with something like the following (CSS can be added to the Custom CSS field of your templates parameters)...
.sidecol_block ul.menu li a {
color: #FF0000;
You would then follow that with CSS for just the child items with something like the following...
.sidecol_block ul.menu ul li a {
color: #0000FF;
Hope this helps
Thats exactly what i needed.
Works perfectly - thank you!
