I'm looking for the setting in the Riley template that changes the color of the showcase right corner that overlays the image. I cannot seem to find it.
Thanks in advance.
This is defined by the General -> Typography - Primary Color field of your template settings. Alternatively you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
