One option is to add a class name to 'Module Class Suffix' of your modules settings. You can then apply styling to this class name using the Custom CSS field of your templates parameters... eg..
Our GridGallery module requires Modernizr to function correctly. To amend this issue could try loading the Modernizr CDN by adding the following to the 'Head Custom Code' field of your templates parameters..
