1. mediafrog
  4. Wednesday, 09 July 2025
please have a look here:
http://joomla4.sylvianopper.net/index.php
I would like to have the pink sidebar-wrapper on the left much wider. I tried to change css, but then the other areas are not longer correct.
Can you help me with this?
Grit
.sidebar_wrapper {
width: 400px;
.content_wrapper {
margin-left: 400px;
Edit to taste.
Hi ciaran,
Thank you very much. On desktop it works fine, but not on mobile. Can you help me for this?
Grit
To amend try also adding the following...
@media only screen and (max-width: 960px) {
.content_wrapper {
margin-left: 0px !important;
thank you.
Please have again a look here:
https://joomla4.sylvianopper.net
I add a border to image on the left, but now there is also a border on the logo. How can I avoid this?
thank you.
Hi Grit
Did you change the template's CSS directly or did you use a custom.css file? You should always use a custom.css for your changes.
To get rid of the border around the image, you could use
img {
border: none;
Be aware that this modification would be valid for any image on the site. As a alternative, you can add some own CSS class to your image and define that class accordingly.
Regards,
Rolf
