1. mvanbergeijk
  4. Wednesday, 13 November 2024
How can I change the color of the header (where the social buttons appear).
Marco
I found out that it only works on the main page. When I click on a menu item the color as specified in the template comes.
https://greenrock.devportaal.biz/index.php
Please can you help me? Thanks
Have you multiple template styles created? A possible cause is that the template style you are changing is only assign to the homepage?
Hello, thanks for your response. I have only one template installed. I can't find where the setting is wrong. Hopefully you can help me further.
It is solved!
