Testimonials module at the bottom of the page doesn't work properly on mobile devices. http://enlivenllc.com/test/ Is it because of my padding setting?
I suspect it is the cause of the issue. I realise you dont want the 'name' aligned fully to the right, is this correct? A solution may be to set a min-width value to your paragraph.
