it is ok.
what is the last update of nina 4: 1.1.3 or 1.1.4 ?
Because when i'm trying to update to 1.1.4 appears always 1.1.3 in the back end.
Thierry
Thank you for bringing this issue to our attention. I have just updated the Nina Joomla 4 template with what I hope is a fix for this issue. To obtain you can re-download your template from your Joomla51 template downloads. After updating your template should be listed as the correct version 1.1.4.
