MENU
  1. Werner
  4. Monday, 26 February 2024
there is a bug in NINA. The links to catagory blogs do not work anymore with an server error 500. If I switch to LAYLA, the lnks are working as expected.
Can this be fixed?
Thanks, Werner
  1. https://www.kerschbaumerhof.com/de/aktivurlaub/tipps-fuer-brixen.html
  2. https://www.kerschbaumerhof.com/it/vacanza-attiva/suggerimenti-per-le-vacanze-al-kerschbaumerhof.html
email with a credentials was sent!
Thank you for caring.
Werener
Thank you Werner
Hi Werner
No nothing was changed from our site. Possibly the issue was due to some cached data that got cleared after a refresh.
Hi Werner
thank you for the quick solution. Perfect as always!
Werner
sorry, but the Italian site has still a problem. The link to https://www.kerschbaumerhof.com/it/vacanza-attiva/suggerimenti-per-le-vacanze-al-kerschbaumerhof.html works, but the blog content has disappeared. Instead you get the message "There are no articles in this category. If you view the subcategories, they should contain articles".
Could you check this?
Thanks, Werner
it's fixed now. Did you do anything? Did I make a mistake somewhere?
Thanks, Werner
