When I created a custom html module in position “bottom-1a”, the Un-Ordered List styling changed to straight lines.
I’m also having transparency problems with the modules, even though I used the exact same template styling as found in the sample data for template style “J51_Cashmere – Parameters.”
When I change Bottom Modules Opacity to 1, the background image is no longer visible in that area. A band of color for Bottom Modules Background appears instead.
Module Class Suffix = title-arrow style-box
If you’d like to see the site I’m working on, I’d prefer to send you the link privately.
