1. hunyuan
  3. Wednesday, 04 February 2015
Hi, I put my logo into the top menu with white background color (FFFFFF), but I cant get the background color to harmonize with it. I changed all settings I could find - then I used Colorzilla to check, the background of the menu is FBFBFB, but I cant find the settings! Please help :)
Best, Sebastian
Site is http://taiji-fulda.de/index.php
also...may I ask how to stretch the slideshow to full screen (from left to right), just like in the demo? slide image width also cuts it vertically :dry:
Hi Sebastian
This area of the template can be styled using the 'Header Background Color' field in the 'Styling' tab of your templates parameters.
An option to set the slideshow module to full width is available in your slideshow modules settings (Extensions -> Module Manager -> [YourSlideshow].
Hi Ciaran, thanks, but unfortunately both doesnt work. The header background color is already set to FFFFFF.
and in the module setting i cant control the slideshow width either. it only makes a change vertically there, meaning cuts or expands it from top to bottom. :dry:
Regarding the header background please ensure you are editing the correct template style for this particular page. The most common reason for changes not been seen in the frontend is due to an incorrect template been edited (Extensions -> Template Manager).
Regarding the slideshow may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I realise now your issue with the logo. There is a very slight gradiant over this area of the template which is showing up the edge of your logo. To remove this gradiant try adding the following to the Custom CSS field of your templates parameters...
#container_hornav {
background-image: none !important;
Regarding the slideshow module I have added it to the 'showcase' module position. It should now be displaying as it is on our template demo.
