1. MikeG
  3. Thursday, 31 March 2016
I was just checking my site for responsive functionality and have hit a problem.
On all other pages, the hornav menu disappears and is replaced by the responsive "MENU" in the top right hand corner. On the homepage, hornav disappears but there is no "MENU" to replace it.
Any ideas please?
I have been doing a little more digging and have discovered that the home page shows this error:
"Uncaught TypeError: jQuery(...).slicknav is not a function"
The code is at (index):314
<script>
jQuery(function(){
jQuery('#hornav').slicknav();
</script>
Can anyone help please?
Hi Mike
Thank you Mike
As jQuery is already loaded within Joomla, I have disabled jQuery in your slideshow module which appears to have resolved the issue.
Many thanks for taking the time to look into this issue and come up with a resolution so quickly. Excellent customer service as usual!
Kind regards,
Mike
hello from austria,
same problem on my site joomla51.hocc.at
menus not opening on tablets and smartphones.
see screenshot - please help - thank you
[confidential]
http://joomla51.hocc.at/administrator/
user: 3213admin3213
pass: Gott0704§$%
[/confidential]
We have installed the 'jQuery Easy' plugin (http://extensions.joomla.org/extension/jquery-easy) which ensures that only one copy of jQuery is loaded across your site. This appears to have resolved the issue.
Hello, I have installed the jquery in response with my slick nav menu not displaying menu listings when click or pointer hovers over the menu box. It's set to be displayed when the screen is sized for mobile devices This solution did not seem to fix my issue unless I needed to use some specific settings in jquery. I was wondering if you may have a solution to my predicament?
Hi Roger
I also do not get the mobile menu. I installed the JQUERY EASY.
Please take a look at http://www.beeckzangh.nl
I have updated your template to the latest download an all appears to be now displaying correctly.
Great.!!!
