1. arconis
  3. Wednesday, 30 April 2014
It seems that the right CSS animation classes are causing a double page width in Chrome for some reason, I've attached a screenshot. It will do it on the demo server.
Image available here:
http://i.imgur.com/V3Q8OMS.jpg
Update: Using animation class with Big at the end (such as fadeInUpBig) creates whitespace at bottom of homepage on Cashmere. Removing Right/Big animation classes fixes all issues in Chrome.
Thank you for bringing this issue to our attention. One possible fix would be to add the following to the Custom CSS field of your templates parameters...
html {
    overflow-x: hidden;
Thanks, it seems to have worked for the Right animation classes.
fadeInUpBig still leaves a lot of whitespace at the bottom of the page and overflow-y: hidden doesn't seem to work, any suggestions?
If your issue is specific to Chrome try adding the following to the Custom CSS field of your templates parameters which will reduce the height of this animation in Chrome..
@-webkit-keyframes fadeInUpBig {
  0% {
    -webkit-transform: translateY(500px);
This does work, thank you :)
