1. artur
  3. Sunday, 19 October 2014
Hello. I am finding some difficulties in cashmere languages templates as for example ; In english language ( http://www.goldbyilpa.com/index.php/en/map ) the map button opens correctly instead in other language ( http://www.goldbyilpa.com/index.php/sq/harta ) no way to open it correctly. I have checked the properties of language and template of the requested page and I don't find anything irregular.
Other thing is the drop down menu; At english version ( http://www.goldbyilpa.com/index.php/en/ - see under CONTACT US ) it function correctly but not possible at http://www.goldbyilpa.com/index.php/sq/ - see KONTAKTO
Can you help me please on solving this issue.
Thank You.
Artur
Hi Artur
I have disabled jQuery Easy and your Google map appear to be now working correctly. Was there a particular reason why you are using the jQuery Easy extension?
Regarding the contacts page issue may I suggest updating your template to the latest version. To do so simply re download the template via your 'My Downloads' and install via your extensions manager.
