I'm using a 3rd party plugin "right click disable" which seems to be using the same function name as my template j51-Interprise. Can you suggest a fix I can make in my template code? I use this plugin on other J51 templates without error. This is the error.
Fatal error: Cannot redeclare hex2RGB() (previously declared in /home/bonnieun/public_html/http://fsrestorations.com/water_fire_restoration/plugins/system/rightclick_disable/rightclick_disable.php:44) in /home/bonnieun/public_html/http://fsrestorations.com/water_fire_restoration/templates/j51_enterprise/php/convert_rgb.php on line 28
I followed similar topics but could not determine a conclusion. Currently the plugin is turned off.
