Using Novah, J5, I can edit the Modules in the Front end, HOWEVER, I cannot edit articles, I Have searched high and low for similar issues with other Joomla Users, Just wondering do you have any idea why that would be?
Hello!
Have you played around with the rights of your user or the posts?
Have you tested a completely new user with "super user" rights?
What rights group does your user have?
What changes have you made to Joomla recently?
Has editing in the frontend never worked before or only now? No longer?
I created a New Super User with SUPER rights logged in and no Change
Logged in with that New Superuser into Firefox rather than chrome and got no Change
Recently upgraded to Joomla! 5.2.3 Stable
Yes, front editing used to work in J3.9 ..... never tested front end editing in J4
If this is still an issue, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
