1. judemac
  3. Thursday, 08 December 2016
I am having difficulty accessing second-level sub menu items on the hornav on a site with a Kindle template.
I can get the first level items but the second-level ones as almost impossible to click on.
Can you suggest anything I can do to make it possible to access them?
(I do not remember having such difficulty with it previously so perhaps an extension update has made it worse).
Thanks for any help
You appear to have some JS conflicts on your site. May I suggest installing jQuery Easy which can quite often solve such issues... https://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
Excellent!.. thank you for the update. :)
Hi Ciarán,
Many thanks for your assistance.
When you looked at the site, the latest version (1.6.7) of that excellent plugin was already installed,enabled and the Enable jQuery option was already set to jQuery.
Any other ideas?
Hi again,
I disabled a recently added module and the menu now works perfectly.
The module contained a code to subscribe to a MailChimp newsletter (the code contained javascript).
Thanks again for your assistance.
