Website address: http://www.bbmb.com.au/
Using the Calibra template.
When the screen size is reduced so that the menu is changed to fit, the submenus are no longer visible. On a pc they are only visible if you hover over them. Is there a way to change the text colour of the submenus so they are visible again?
