1. KChev
  4. Thursday, 29 May 2014
The mobile menu is not appearing in dev.anciennebergerie.com despite having followed the instructions regarding mobile menus. At one point during the development I did see it but no longer and I have no idea what I did to cause this problem. I have much experience with your templates now and this is the first problem of this nature.
Thanks in advance.
Hi KChev
May I suggest re sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
I have disabled jQuery in your slideshow modules parameters and your mobile menu is now working correctly. jQuery is loaded by default in Joomla 3.x
Thanks, I didn't know that about JQuery. I've been turning on JQuery in the slideshow modules all along and this is the first time I've had this problem. Maybe this is the case only in J3.3? (By the way, there is a bug in 3.3 that prevents you from uploading image files to a folder using Media Manager, which is a real pain.)
Hi KChev
Issues can arise if jQuery is loaded twice on a particular page. As jQuery is loaded by Joomla 3.3 by default, as a rule you can disable jQuery in any extension you are using presuming the option is available. You could also consider installing 'jQuery Easy' (http://extensions.joomla.org/extensions/core-enhancements/performance/jquery-scripts/18327) which ensures only one copy of jQuery is loaded across your site.
All going well the Media Manager issue will be amended in the next update of Joomla... http://joomlacode.org/gf/project/joomla/tracker/?action=TrackerItemEdit&;tracker_item_id=33413&start=0
Thank you, ciaran, this post solved my problem.
