1. dayhiker.be
  3. Monday, 07 April 2014
Hello All,
I have two problems with my new site http://www.dayhiker.be.
The first problem is that there is under the articles a second menu identical to the main menu on top of the site. Is there a solution to remove it?
The second problem is with the article options. I want to use rating for all my articles but not for my about page. In the main options I activated rating and for the article about I took No rating. But that doesn't work.
Someone who can help me please?
Thanks a lot already for any help.
Peter
Ok, found it!
Thanks for the information and keep up the good work.
P
Hi Peter
The top menu and footer menu of your template are set within your templates parameters. By default these are set to your 'Main Menu'. You can change this by navigating to Extensions -> Template Manager -> [YourTemplate] -> Options -> Menus.
Second problem solved. Setting menu change and not setting article.
So the first problem is still actual. Home Menu is coming on top and on the bottom.
Thanks 4 any help.
P
