1. judemac
  3. Tuesday, 15 April 2014
My client would like to have a grid set up on her homepage, I've done this, but can't clear a white box (?) that should hold body text.
The other issue is changing the colour of the headings in linkhover, which I installed.
Lastly, for some reason the menu I set up in a module on the homepage has decided to centralise itself, I made a copy of the homepage, with the gridgallery, giving my client the choice, that one is perfect, yet it's a copy?
Url - http://www.stornowaytown.co.uk/
As usual help is much appreciated.
Judy
To remove the article/component area (white box) of your template completely try adding the following to the Custom CSS field of your templates parameters.
#container_main {
    display: none;
Presuming you wish to use this area on other pages of your site, you will need to create a separate template style specifically for your homepage to which you will add the above CSS. For details on creating multiple template styles please check out the following tutorial... http://www.joomla51.com/tutorials/item/creating-multiple-template-styles
To change the color of your linkhover titles try also adding the following to the Custom CSS field of your templates parameters where #000000 is your new title color..
.j51imagelinkhover h3 {
    color: #000000 !important;
Thanks Ciarán that worked a treat.
What do I need to change the titles in -
Base 1 positions, bottom menu and copyright,
So I can co-ordinate the colours to tie in with the rest.
Love the latest templates, can't wait to try them.
Hi Jude
For the base-1 titles you can use the following...
#base .module h3 {
     color: #000000;
For the copyright text use the following...
#copyright p {
     color: #000000;
And finally for the footer menu items use the following...
#footermenu ul li a {
