1. Glen
  4. Monday, 06 March 2017
Calibra - Floating Issues.
For some reason the second layer (across) of feature articles on the home page will not float properly. The text on the left side should be centered, and the image on the right should be floated right. Image attached. The issue can be viewed on this page: http://www.canwood.ca/
All the other rows float just fine.
Seems to be something with:
<div class="items-row cols-2 row-1 row-fluid clearfix">
Blog layout across:
On this page: http://www.canwood.ca/administration/council-and-minutes - the right column is floating too far to the right, even though it is just one <ul> deep. If I add more text to any one of the list items then it does push it over to the left, like in this page:
http://www.canwood.ca/administration/bylaws-permits.
Another blog layout page can be seen here:
http://www.canwood.ca/business/directory
and here:
http://www.canwood.ca/recreation/village-recreation
Thank you Ciaran
That fixed it.
Cheers.
We are getting the following error when we try to access your site...
403 - The webmaster has forbidden your access to this site
Our current IP is 86.40.159.164 (Ireland).
Yes, sorry - I had Europe geoblocked because of all the spamming from Russia. Will turn it back on.
Can you try again.
G
Thank you Glen
To amend these issues try adding the following to the Custom CSS field of your templates parameters...
.blog .column-1, .blog .column-2, .blog .column-3, .blog .column-4 {
width: 100% !important;
Great... thank you for the update! :)
