1. webbie
  4. Wednesday, 20 July 2016
Hello, in Caitlin template i can choose in responsive view, if the sidebar comes first or later. At my template it does not work. Also i want the distance between the top and and first content reduce in responsive view.
Can you help me with that?
I made the template settings Sidecolumn Positioning to ->After Component - but still it is before component
My url: ralphbosse.text.bz.it
Thanks a lot!
Hi Webbie
#main {
display: flex;
flex-direction: column;
.sidecol_a, .sidecol_b {
order: 1;
You can reduce the height of the header on various sceensizes by adding the following to the custom CSS options within the 'Responsive Options' tab of your templates parameters (edit to taste)...
#header {
height: 60px;
This works great! Thanks a lot!
THX ciaran,
it also works with the "Nadia" template :)
