1. deaksie
  4. Thursday, 08 March 2018
I hope you're well,
Just adding some buttons to my website sesseto.com, and I'm finding that the style of the button is nothing like the attributes I've applied in the template (colours etc) You can see an example in the Welcome to Sesseto section on the homepage, and then on most subsequent pages.
I'd like it to be a block colour with rounded edges, which is what normally comes out.
I've tried css override but it's ignoring that
Many thanks in advance
Liz
Hi Liz
All is well. Hope the same on your end.
Hopefully I understand you correctly but could you try adding the following to the Custom CSS field of your template settings..
.btn, button {
    background-color: #3d4280;
    color: #fff;
    border-radius: 5px;
Thanks for the prompt response - efficient as always.
That worked fine! I needed to insert it above the other .css which I think was the problem.
Much appreciated
L
