This issue should be now resolved. It appears some overrides were not getting updated correctly. To resolve I deleted the ../templates/j51_nina/html folder and re-installed the template to re-instate it correctly.
Thanks does look fine now. I will try the same procedure on the other sites and will post here if there are any issues. Note the Download page still says 3.0.2 but the changelog says 2.0.3 for Nina. It would be usefule if the changelog or some other indication of version found its way to the download - or is it there and I have missed it ( more likely)
