1. tcm1003
  4. Sunday, 08 January 2023
Hello all,
I have an error in the extension ImageHover that a linked image is not opened in a lightbox. It just opens the image directly. The error is traceable on the following website: Titlehttps://kellerclubimstuz.de - there at the very bottom left the two images (with heading "Way to the basement";). Or have I possibly forgotten any settings?
I would be glad about support. :)
(PS: I need a J4 upgrade coupon for Magnolia, is it possible to get one or rather a separate thread for that?)
Hello all,
Siehe hier: https://www.joomla51.com/blog/item/joomla-4-template-update-timeline
Hello all,
Thank you very much and I apologize very much. I didn't catch this list and was expecting it to happen via forum posts like it did back then. Thanks again. :)
Little push for the original problem.
I have an error in the extension ImageHover that a linked image is not opened in a lightbox. It just opens the image directly. The error is traceable on the following website: https://kellerclubimstuz.de - there at the very bottom left the two images (with heading "Way to the basement";). Or have I possibly forgotten any settings?
Is there any help?
Hello and thank you for your help.
I have created an account for you and also sent you the login details, so there should have been two emails about this. I hope this helps to find a solution. I am curious. :)
Thank you. Installing the latest download of the ImageHover module appears to have resolved the issue.
Thanks for repairing.
But where can I get the version 2.1.4?
If I download Ariana J4, inside is version 2.1.3. In my joomla51 account via joomla extensions there's version 2.1.1. So, how do I get the file for the version 2.1.4? :o
Hi Tore
The J4 version of the ImageHover module should be now available for you to download :)
