1. RedScorpTec
  3. Wednesday, 25 July 2018
I just found a bug in the icon module. If you add a URL to the icon in the settings, it seems as if the mobile css is set as default.
The icon-module width takes 100%, so the next icon comes in the next line.
If there is an update or something you can help me with, it would be cool if you let me know. Thank you!
Please find attached the latest download of the Icons module. Installing via your extension manager will resolve this issue.
Worked great! Thanks for that!
Is it time-consuming to give the icons / buttons a hover effect? That would be ultimate.
Greetings (:
Sören
Hi Sören
Would you have a URL to an example of your icons module? What kind of transition are you looking to achieve?
