I have a problem with the breadcrumb in the template Virtuoso (Joomla 2.5.19) as you can see in the attachment. I made no modifications in the css code. Do you have a solution for me?
Yes, it's o the "breadcrumb" position. But in the meantime, I've found the cause of this problem. Before I installed Virtuoso, I had used a different template (not a Joomla51 template). After I uninstalled it, breadcrumb is correctly displayed now and the problem solved.
