Downloaded Boutique With Sample Data - Copied To htdocs.
Had to edit joomla.sql and sample_data.sql - replacing ENGINE=InnoDB with ENGINE=MyIsam
When I try to install I get the error
Variable 'character_set_client' can't be set to the value of 'NULL' SQL=/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '-- MySQL dump 10.13 Distrib 5.6.24, for Win32 (x86) /*!40101 SET @OLD_CHA' at line 1 SQL=-- MySQL dump 10.13 Distrib 5.6.24, for Win32 (x86) /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */
Any Ideas
