1. patrickbmccabe
  4. Friday, 19 June 2015
I am trying to slow down the image fade in the home page in this site http://cff.corranny-media.com/index.php. Could anyone tell me how to do this?
Hi Patrick
A field is available within the template parameters of our Caitlin template to edit the delay. You will find this within the 'Styling' tab (Header Slide Interval).
I'm trying to do the same thing again except this time in the Template "CAITLIN"
but the Vegas background slide show is not in the same place... ../templates/j51_Caitlin/php/scripts.php
Did it move?
Thank you Ciaran That worked for me
Hi Patrick
In your templates scripts.php (../templates/j51_boutique/php/scripts.php) locate the following block of code...
<!-- Vegas Background Slideshow -->
(function($) {"use strict";
$(document).ready(function() {
$('#header_slide').vegas({
delay: 5000,
timer: false,
slides: [
<?php
if(is_array($header_json['header_slide_image'])) {
foreach($header_json['header_slide_image'] as $value) {
{ src: '<?php echo $this->baseurl ?>/<?php echo $value; ?>'},
<?php } } ?>
})(jQuery);
</script>
In which you can edit the delay to your own taste...
delay: 7000,
I found this code in the online page
element.style {
transition: all 1000ms;
-webkit-transition: all 1000ms
But cannot find that in my local version.
Which style sheet is this contained in?
