1. kpomilla
  3. Wednesday, 10 December 2014
Hi, I have a problem with the Boss Template. I want to adjust the location of the hornav menu, but the only setting I see is the ability to set the offset for the logo, not the menu itself.
Is there a way I can adjust the vertical location of the menu?
Ken
Hi Ken
Would you have a URL to an example of your menu and details on how you would like to adjust it?
http://amfglobalsolutions.com/coppertecdemo/
I'd just like to raise it up or lower it, based on the picture so viewers can see the menu text against the background.
Hi Ken
Not sure if I understand you correctly. Moving the menu upwards would mean the menu is located on top of your logo, lowing would leave a gap between your logo and menu?
I know I can place the logo anywhere using the logo x y location settings...What I want is to be able to load the page with the menu perhaps higher or lower, and I'll then adjust the logo accordingly.
