1. marco.diroio
  3. Thursday, 03 January 2019
Ciao :)
Using Boss without awesome fonts (i.e. switched off ) and no logo image but only logo text and slogan..
I have the side effect that the drop-down menu appears too lower than the top menu items and disappears before the pointer wraps up the submenu items.
1. How can I raise the drop-down menu next to the top menu (like before disabling fonts)?
2. Another question for the Boss template. How can I use the left or right slideout effect (i.e. of elvira) for the menu in mobile mode?
Grazie mille!
#hornav li:hover > ul,
#hornav li ul li:hover > ul {
top: 36px;
Hi Ciaran.
1. Here in the homepage a case test : http://yuukaidojo.netsons.org/
If it can help you, I attach two screens (before and after loading Font Awesome)
Thx!
Hi Marco
1. Would you have a URL to an example of this issue?
2. Sorry to say at present this option is not available with our Boss template.There is a number of 3rd party extensions which may allow you to add similar mobile menus to your website. A good place to start would be https://extensions.joomla.org/category/menu-systems/
