using BOSS-template 1.2.1 since 2014 without problems. But now after providers PHP-upgrade to. 8.0 nothing works. No access to backend or frontend.
Is this a template problem ? You will find an error log in the attachment.
Considering also your administration would suggest that this is not related to your template which will only affect the frontend, Can you confirm that all your installed extensions (most likely plugins) are PHP 8 compatible?
