1. ukfish1
  4. Wednesday, 23 March 2016
ref: http://www.prioryfarmfishing.co.uk/demo/
I want to remove the faint borders to the left and right of the main content area and the 4px border at the bottom. When I check firebug it says the class is .group-border-shadow
can you advise where to change this please.
Paul
Hi Paul
To remove try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.group-border-shadow {
border: 0 none;
box-shadow: none;
Thanks Ciaran but that doesn't appear to have worked.
Paul
Hi Paul
We are unable to see the suggested Custom CSS been loaded on your page. Ensure that you have added the CSS to the correct template style and field. Failing that may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Sorry, I added the code to the custom.css file but forgot to activate that file in the template parameters.
All good now though thanks
Paul
