1. ziggy
  4. Thursday, 22 November 2012
I have problem with Bordeaux template. I need to have multilanguage site so I did everything through the tutorial but the language switcher is not working in Bordeaux template. It is working with no problems in default template...
Thanks for help
my site:
horsediamond.com
Lukas
Hi michno
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further.
I have sent you the password... Thank you
May I suggest the following post which details how to convert the top menu area to a module position allowing you to set up a multi-language menu module as normal (Avenue template but will also apply to our Bordeaux template)... http://www.joomla51.com/forum/support/commercial-templates/hornav-module-not-visible-in-avenue#627
You can then create a menu module in this position for each of your languages. I have created a working example for you in the bottom-2a module position.
