I have taken the coding from your example to put a simple bootstrap panel in both an article and a Custom HTML Neither work. Is there additional configuration I require?
Hi There
I have a similar problem, could you advise me how to do this. I still have the template on localhost on my pc for testing.
Need the bootstrap to look like template demo Virtuoso.
Perhaps I am missing something but I have entered the code into the custom Head section of the template settings and still not showing the effect as in the demo.
I'm using the Xamp and my joomla installation is 2.5.14 and J51-Virtuoso 2.5 Template.
I also installed it on another template online and also get same result.
