1. keithvb
  4. Wednesday, 31 March 2021
How can I remove the blue icon that appears on Ensley's footer menu?
How do I prevent the log from changing size on scrolling?
website is artgallery.keithvb.com
thanks as usual,
Keith
Hi Keith
.module .module_header h3 {
padding-left: 0;
.module_header::after {
display: none;
.is-sticky .logo img {
max-width: none;
Thanks the logo no longer resizes when scrolling.
How can I remove the blue icon from the footer menu? Please see attachment above.
Keith
Hi Keith
This is part of the background image to the module block. You can remove this image via the General -> Modules/Component Styling tab of your template settings.
Thank you!
