1. mesquite
  4. Thursday, 24 June 2021
Could you explain please how you achieve the 'look' of the layerslideshow on the Bianca Demo template.homepage?
I really like the look.
Terry
Hi Terry
Firstly add an instance of the LayerSlideshow module to one of the showcase-1# module positions, ensuring to enable the Overlap Header if in showcase-1# module position option in the General Settings tab of the module settings.
Secondly, to curve effect is displayed above any module in one of the top-1# module position.
I hope this helps :)
I'm confused with the second part of your instruction regarding curve effect is displayed above any module in one of the top-1# module position?
Sorry, but doesn't make sense.
Terry
Hi Terry
The curved shape between the showcase and top-1 module positions is only displayed if a module is enabled in each of these positions.
I've done this and to no avail.
I've created you LOGIN details which I'll email.
Terry
Thank you Terry
I have checked the login details provided however it appears only the Stella template is installed rather than the Bianca template. Please note that this option is only available with the Bianca template.
I've installed the "Bianca" template but cannot get it to work?
Terry
Hi Terry
I have updated your slideshow module and it appears to be now displaying correctly.
Thanks Ciaran but can you send me a copy of the updated module for future use.
Terry
Hi Terry
We installed the module bundled with your Bianca template. You may have been still using the LayerSlideshow module from another template?
