1. DSWrights
  4. Friday, 19 December 2025
With the Bianca template, when you scroll down the menu vanishes from sight. is there a quick fix to have it shown despite scrolling?
Hello, does the template have a sticky header function in the settings?
Please check there.
Would I ask in the first place if I knew or found it? Not helpful
And why don't you simply check the template settings yourself to see if the function is available?
I've installed the template on a test environment for you to check this. Yes, the function is there! You could also have viewed the template settings on the demo page.
Here you are!
I looked but couldn't find it. Hence my post.
Thanks for pointing out where exactly to look. Have a great day
No problem Frauke, good luck ;-)
