1. DSWrights
  4. Thursday, 07 March 2024
When I noticed that the rotate module wasn't installed, I looked into the install files, where I found it.
The problem is that it simply lists all items below each other, even though "Items Displayed" is set to "1".
I also set all "Responsive Options" to "1" as well.
Thing is, that I cannot use the testimonials module for this, because I need to link the texts to the products. I've checked and the rotate module is not officially part of the Bianca template. Is there a possibilty to make this work?
Thanks!
Which version of the Rotat module are you using?
Do you have a link to the page where the error can be seen?
Can you show a screenshot of your settings in the module? (Tab: General / Iteams / responsive option )
Like I said: I used the one provided in the zip of the template.
https://www.dswrights.de/ - but one doesn't really see anything as it doesn't rotate and I have deleted all additional texts, since the page is live.
I used the same setting as on a different homepage with a different template
I use module version 1.0.2!
In the settings under ITEMS PER TRANSITION I don't use "page" but "1" . then it works for me
Thank you! I didn't see that - changing the ITEMS PER TRANSITION to 1 did do the trick!
Danke sehr!
