1. nebuladesigns
  4. Saturday, 26 March 2016
Hi There
Can the beaumont menu bar have a transparent or OPACITY set when scrolling further down the page? Currently the background color is displayed.
Also, can you please advise on responsive code for slider/header images. When I resize browser, the showcase images are not responsive.
Site under construction and I can PM the URL and access details.
.is-sticky #container_header, .is-sticky #socialmedia, .is-sticky .header-1, .is-sticky .header-2 {
The background image of the header area is set to cover the space available. Disabling this will cause a space to appear below the image. As the image reduces in width, the height will also be reduced resulting in an empty space below the image.
Is there an option of making the header images responsive for mobile devices, if not, can the header images be omitted from mobile devices.
To enforce the images to resize to the width of the screen try adding the following to the Custom CSS field of your templates parameters...
.vegas-slide-inner {
background-size: 100% auto !important;
Thank you, i have implemented the code and it works. Although there is quite a bit of blank space below the slider. I can live with that. Will play around with css code and see what else I can do to improve the mobile appearance.
I am really excited about this project and will post it under showcase soon!
If you have a URL to an example of the issue we would be happy to have a look for you.
