The website http://www.gosfordpc.com.au uses the new Beaumont template and the J51_carousel. My problem is that the carousel mod is playing up for me. I've recorded some videos of the issues to make it easier to see whats going on.
First problem, sometimes when I go to the site and scroll to the footer and then back up to the top the carousel is still running but the words are no longer in the correct position and the slideshow picture has been cropped at the top.
http://www.gosfordpc.com.au/joomla51issue1.mov
The second, is in the same circumstances, pages loads scroll to footer and then back up to the top but this time the carousel module is gone causing the slideshow image to mostly disappear.
http://www.gosfordpc.com.au/joomla51issue2.mov
Lastly, I've been playing around with the slideshow and the carousel modules timings so that they will transition at the same time. Do you know what timings are required that will make this happen? I can get it in sync for 3 passes but after that it is obviously out of sync.
Joomla version: 3.5.1
Browser: Chrome and Safari
Running on hosted hardware (http://www.netregistry.com.au)
